We have installed a EasySolar 12/1600 and are getting an overload Alarm . The only reason I know it’s an overload Alarm is from the Phoenix multi control screen when connected via the MK3.
What is the overload alarm ? And how do we clear it ?
Hello @keystones19,
There is a detailed webinar here
https://www.youtube.com/watch?v=4SXtGIx0x5w
That explains the overload conditions for Victron inverters, what can lead to them, and how to reduce them.
Thanks Guy.
We are greeting the overload alarm, but we have no AC load. The system is new and has been commissioned with the MK3 as required. Can you force re set the unit to clear the Alarms.
We have charged the batteries with a 12 volt charger to get them to float. With have eliminated any issues potential with the caravan MEN. We haven’t altered the breakers or RCD or any internal wiring of the unit.
The dealer we have purchased it from are sending out another unit but I am keen to understand more before we swap it out.
Any further ideas would be greatly appreciated,
Regards
Dan Walters
I think the dealer is on the right track.
Overload errors will normally self clear. And should always clear after a manual reset. So there is possibly a fault.
9 People are following this question.
