Showing amperage on L1 out and negative amperage on L2 out. Only DC is connected. Nothing wired into AC out. Any idea as to what is happening?
How much ? External AC sensor?
https://community.victronenergy.com/questions/180359/i-see-ac-loads-while-nothing-is-connected.html
You're not the first one to post this issue, but I have not seen a response by victron. I also get the negative output on L2 when in inverter mode or single phase input. My system shows exactly double the negative output (I have parallel MP2's) six hundred fifty something negative amps on the L2 output. I think there are probably a lot of people that have the same issue but they don't know it because you only see it if you are looking at the output thru node red, mqtt, or victron connect via a MK3. It doesn't appear on the GUI except for in the device list.
Edit: this is on the MP2 2x120, all the posts I have seen is for the same unit. I have seen several more posts about this issue on a few Facebook groups.
92 People are following this question.
