nervousfrog avatar image
nervousfrog asked
Node Red on Windows
Hi all and thanks in advance for any advice.
Until recently I have been using HA with my Multiplus II so I have been using TCP Modbus successfully with that.
I decided to give Node Red a go and have come a bit unstuck.
I installed Node Red on a Windows machine and installed the Victron addon and I can see all the nodes.
But I am getting the following error
Error connecting to dbus: Error: connect ENOENT /var/run/dbus/system_bus_socket
I'm guessing it's because I need to set NODE_RED_DBUS_ADDRESS= but the instructions all have the Unix path I'm not sure how or where to set that value.
Any advice is appreciated.
Node-REDModbus TCP
afaik there is no dbus on windows.
matt1309 avatar image
matt1309 answered ·
Hi @nervousfrog
I assume you're looking to read dbus on a GX device?
In which case i think you need to setup Dbus over TCP to remotely connect to the dbus running on the GX device.
I believe most folk use the node red running on the GX device (assuming they have venus os large installed)
I've never done this myself but I think it's explained here:
node-red-contrib-victron (node) - Node-RED (nodered.org)
nervousfrog answered ·
Thanks for all the feedback.
I was trying to avoid using the built-in NodeRed as I was a bit wary of the warnings from Victron that it's 'unsupported'.
I already have Dbus over TCP setup and working with Home Assitant and that works fine.
I think the issue I am having is there is a file somewhere in the VM that needs to have the following value set with my GX IP.
      1. Environment="NODE_RED_DBUS_ADDRESS=192.168.1.9:78"
    As per this thread https://community.victronenergy.com/questions/35001/external-node-red-on-ubuntu-connecting-to-ccgx.html
    But I can't find /lib/systemd/system/nodred.service. in my file structure.
    I have managed to do what I need to do in the short term with a HA script so I will put Node-RED on the back burner for now I think.
    Again thanks for the advice.
