Bought two Multiplus II 48/5000/70 One of them does not show any ledlights, panel is black, but the inverter seems to work, 234V/50Hz I can not find if there is any input to make the led lights to light up in the manual. Did I miss something?
Maybe the ribbon cable to the LED PCB is loose. Open the cover and check that.
Thomas answered · 3 secs ago
You were right, the cable shoe to the led light had come loose inside the inverter. It works OK now thanks!
88 People are following this question.
