chrigu avatar image
chrigu asked
Multiplus 24/800 DC-coupled ESS
Hey
I got a used Multiplus 24/800 with a couple of AGM batteries for a good price.
I want to use that as an energy storage system. I also have two 350W solar panels, at the moment hooked up to a 600W micro inverter. I plan on changing this to a Victron MPPT charger, to charge the batteries with it directly.
Now the, maybe, tricky part. Can i set up the Multiplus in a way that it will use the battery optimisation mechanism, but feeds 100W of power continuous (if batteries are full enough) into the grid?
Reason is, i dont have an energy meter than counts backwards or counts the export seperately. So any power fed back is a gift to the power company.
So i would like to cover my base usage of around 200W as much as possible troughout the full 24hrs of a day.
I would like to not install an extra power meter or a GX device. There will also be no loads hooked up to the AC out of the multiplus.
Is that possible?
MultiPlus Quattro Inverter ChargerESS
