alaskannoob avatar image
alaskannoob asked
Cerbo GX relay wire gauge?
Just wondering if there is a particular wire gauge that should be used (or a min/max gauge) for the relays in the Cerbo GX. Would 16 GA wire work?
I'm about to wire in a two wire start/stop for a generator and I've seen some discussions of relays frying on the Cerbo...I just want to make sure I do everything I can to keep that from happening before I try it. Many thanks for any suggestions!
cerbo gx
kevgermany avatar image
kevgermany answered ·
I can't remember the value, it's in the manual, but Cerbo relays are for low current loads. Pick a guage based on current and voltage drop over distance. Common acceptable value is 3% max voltage drop.
Fideri avatar image Fideri commented ·
@AlaskanNoob
I was looking for the same info and didn't see it in the manual. Did you ever find out?
F.
alaskannoob avatar image alaskannoob Fideri commented ·
No, never did.
alaskannoob avatar image alaskannoob commented ·
I didn't see it in the manual, but maybe I missed it. If you think it's in there, what page number did you see it on?
seb71 avatar image
seb71 answered ·
I don't think AWG 16 fits in the connector, but I haven't tried it.
Use a ferrule on the wire end.
