Hello!
Thank you!
I have been trouble shooting for days.
I have 6 - 100amp 12volt batteries. System worked great no issues. Then slowly I wouldn’t keep power over night.
Then a storm came through and blew the extension chord. And since then:
- my system only works with direct solar power
- battery bank detached, tested all 6 and then all came up good 13.5 ish.
The bank seems to not be charging. When plugged into shure power multiplus 12/3000/120 rotates from “overload” “temperature” shut off to inverter on. Overloads and resets.
The smart BMV says my battery bank is at 100% but if that’s true my system is pulling anything, becuae it crashes and I loose ALL power.
I can’t find the multiplus in the device list, can’t find the ESS setting access.
I have not signed into my VRM. It’s my ex’s set up and I don’t have access but I could find a way to get it.
Here are a bunch of pics and videos.
I’m slowing working my through terms and manuals. Please be very detailed oriented. Like where things need to be plugged in.
An
I unplugged the BMV:
With BMV plugged in:
