PeterM avatar image
PeterM asked
Multis in parallel - how does system determine actual battery current
When you have multiple Multiplus in parallel how does the Venus device calculate actual current going to battery ( as part of ESS control loop ) - does it measure the battery in the master and multiply by number of multi's in parallel or does it sum all the currents.? I am trouble shooting a system where system s behaviour varies depending which multi is set to master.
Multiplus-IImultiplus in parallel
