bonsys avatar image
bonsys asked
Limit internal charge to prioritize other energy sources is not accounting for temp compensation
I do welcome the new beta feature introduced by Victron in the lasted Multiplus-II firmware: "Limit internal charge to prioritize other energy sources". However, I am observing that the logic is "blind" to temperature compensation offset. In my case, I aim to float AGM batteries at 13.6V with solar when possible (mppts have temp compensation defined as -18.0mV) and with the Multiplus taking over once solar is off. I set Sustain Voltage as 13.6V and Multiplus took over solar right away since the battery temperature was above 25C and mppts were floating at 13.42V (13.6V - 0.18V to compensate for 1C). Will be nice to add temp compensation as an additional param to that screen or derive the offset value from the charge screen.
Multiplus-IItemperature compensation
