I am logging my MPPT 100/20 and get above image on a good day when the rated amps are drawn for extended periods.
Red is temperature, green the charge state, light blue pv voltage, blue the Amps, yellow battery voltage and green actual watts made.
At 65 degree the temperature , when presumably further rising, reads erratic values. Is the MPPT giving out false values?
Also, when reading this
And looking at my graph or following my BMV "by hand" it does not or has ever derated. When charging my scooter it has to bring the rated power for hours and does. I wonder whether everything is alright, I am not complaining as it does exactly what I want it to. Not that it has much of a chance to do otherwise as it is factor 4 overlayed with over 2kWp.
