Dear All, Dear Victron Team
I have several questions for the EVCS integration in the victron app and the EVCS Webserver:
1) Why I need bluethooth connection if the Wallbox is fully integrated in my WLAN network? Unfortunately the bluetooth is not strong enough to get everywhere connection to the WB in my house via bt and I have to switch between the app and the webserver ...
2) What is the reason to have not the same function and features in the app e.g.:
- Scheduler modification
- no general settings from the webserver available
3) Why is the option missing to create sereral user?
4) Is there a way for language changing?
5) Why the Total energy value resets (modbus 5021) on nearly every session and not accumulation as you can see on the webserver.
6) Why the min charging current limit is 6A? For example, a Tesla M3 can be controlled by the app to 5A and via communication even to 1A (down to 4A / 3A would also help in the discussion for switching between 3P and 1P). With 5A I can charge my Tesla over night with 1x MP2 (200-300W house load) without grid power but then I must work on minimum 2 apps :-(
Thanks in advance for your feedback / comments
Regards Christian
![1692129615331.png](/storage/attachments/59593-1692129615331.png)
