sto avatar image
sto asked
Orion TR Smart 12 12 18, reduce charge current
Is there a way to limit the charge current of the Orion charger? My wiring allows for max 10A otherwise the voltage drops too much.
I could not find anything about that in the configuration menu.
If it can't be configured, is there a feasible workaround? Running new wires won't be possible with any reasonable effort, and 10A is really all I need as a charge current.
orion-tr smartcharge current limit
thomas-dd avatar image
thomas-dd answered ·
If the current is limited by the cables the voltage drop only applies at high currents. In later lower-current charging states you will have the full voltage (by basic R = U/I relation)
kevgermany avatar image
kevgermany answered ·
There's no current control. It's limited by the battery you're charging.
is there any device known, which offers to limit currents?
You might get it working by putting a high current diode in the input side, not the battery side, but I doubt it.
