vladimir avatar image
vladimir asked
Cerbo GX will lose its complete configuration upon reboot or power failure
I have Cerbo GX installed on boat. There is now firmware version 3.01 Large with node-red.
After each reboot or power failure it loses all configurations and I have to make all configurations again and upload node-red flow, because it is also lost.
Firmware upgrade from 2.9 Large to 3.01 Large does not helped.
Factory reset ( venus-data.tgz ) does not helped.
SSH connection show me, that data partition is empty, so the problem described in another post is not the case.
root@einstein:~# df
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/root               981568    864500     46580  95% /
devtmpfs                465376         4    465372   0% /dev
tmpfs                   515040       912    514128   0% /run
tmpfs                   515040       808    514232   0% /var/volatile
/dev/mmcblk1p5         1134336      4564   1054100   0% /data
/dev/mmcblk0p1        15691776       192  15691584   0% /run/media/mmcblk0p1
tmpfs                   515040       912    514128   0% /service
overlay                 515040       808    514232   0% /var/lib
root@einstein:~#
Can you give me some hint, what I have to do? Thank you very much.
cerbo gx
@vladimir
this is not normal behaviour, I would take the unit in for a warranty check/replacement.
The node red loss on update can happen, that is why in the instructions you are told to make a back up.
But all settings should remain on normal reboot or power down otherwise.
jim-henault avatar image
jim-henault answered ·
My Cerbo is also losing setup info after a reboot... Is there a solution?
Thanks!
@Jim Henault
Yes it is a called a warranty replacement.
