I have a parallel configuration of 2 x Multiplus II 5KW inverters running in ESS mode with 12kWh lithium battery and DC coupled solar. The inverter "Switch" (shown below in the remote console below) randomly turns off every now and then for no apparant reason. I have attached below the most recent incident of this occuring at 09:00 on 9th AUG. As you can see the load is ony 250watts and there are no alarm notifications on 9th AUG to indicate why this has occcured. Help is appreciated. I am able to provide a log in access to this portal for an expert that can potentially help solve the mystery...
![1691544708734.png](/storage/attachments/59110-1691544708734.png)
