Cerbo gx firmware 3.01 lost bluetooth from setting, temperature at 65deg, when going back to firmware 2.85 bluetooth coming back to setting. not temperature problem. Is there a bug in this 3.01 firmware?
Problem solved, it's not temperature related as some people say BT shuts down when it's 53°C (over 120F) at the CPU, I measured the temperature and it was barely 82deg, it's definitely a bug in the firmware but, here is how I solved the problem. I just want to mention here that all this started when I added the TP-link USB BT adapter and I had to update the firmware above the V2.85 to have the cerbo GX work with the Mopeka sensors, I revert from V 3.10 to the previous firmware version V2.85 while the USB BT adapter is still plugged into the USB in the cerbo GX, the BT line show up in the setting but the Mopeka sensors are not showing as it will only work with the V2.92 or later version, this is good as it show that it's definitely not a temperature related, at this point I revert back to the to the V3.10, BT is not showing up in the setting but at this time I disconnected the power from the cerbo GX (reboot from the menu will not work) waited few seconds plugged the power back and BT is showing up, sensors showing, and everything is working. I hope this will work for you guys that have the same problem and I hope that Victron will figure out this problem in the firmware so other people will not have to go through all this.
The temperature shutdown on the BT is 53°C at the CPU. So no bug, still temperature related, this of course depends on your cerbo HQ number (berfore HQ2207). The newer ones dont have the issue.
And we are running both those versions and BT is working on my cerbos.
Hi all,
Really, the only way to have reliable bluetooth on a Cerbo with serial HQ2207 or earlier is to use an external USB Bluetooth dongle.
The bluetooth hardware in those Cerbos is unreliable. Firmware updating it is alreadt enough to trip it up.
Its not good, but still is how it is. We’re not giving support on those Cerbos wrt built in bluetooth. We’re not testing it when making a new version of Venus OS either. Its simply too unreliable.
67 People are following this question.
