janlerouxrsa avatar image
janlerouxrsa asked
Blue Solar MPPT 150/45 Error Battery High Voltage
I have a Cerbo GX connected to a Hubble Cloudlink. Also connected is an MPPT 150/45 and a smart Shunt. All devices show up in the Cerbo GX. I have 3 x 330watt solar panels connected to the MPPT. When I connect the solar panels I get an error. #2 Battery High voltage. On the Cerbo GX I have DVCC se to Forced on as per documentation from Hubble. Can somebody please help on why am I getting a battery High Voltage error.
MPPT Controllerscerbo gx
4 comments
@janlerouxrsa
Is it on the latest firmware or was it at least uodated on install? Has the blue solar been programmed?
If not that is likely the cause.
Particularly if the system voltage was auto detected then not actually set after.
janlerouxrsa avatar image janlerouxrsa Alexandra ♦ commented ·
Hi, I'm not sure if the latest firmware is installed.I have not configured the MTTP before. I had tested it on another battery before with a 24V voltage. Are there any way to configure the MTTP via the Cerbo as the site is very remote.
Alexandra avatar image Alexandra ♦ janlerouxrsa commented ·
That wil be it then. It auto detected the 24v, not it is on a larger battery it thinks there is a problem and is preventing charging.
If it was a 24v battery at 48v it would be massively over charged ;)
Won't the MPPT everytime it is connected to a new battery remeber the new voltage? Do I understand correctly. It was once connected to a 24V system. I reconnected it now to a 48V system but it still remembers the 24V setting?
Is there any way to change the setting via the Cerbo or VRM Portal as this site is very remote?
mrkev avatar image
mrkev answered ·
Interesting! You're having a similar problem to me - https://community.victronenergy.com/questions/222228/error2-bluesolar.html
I wonder which firmware you're running?
janlerouxrsa avatar image janlerouxrsa commented ·
v1.61
nickdb avatar image
nickdb answered ·
The MPPT will have chosen 24V then so you need to change it to 48V.
You can use the victron connect app, via VRM to access the MPPT settings, so you can properly configure it.
mrkev avatar image
mrkev answered ·
Ah, maybe my problem is a little different - mine have only ever seen 48V packs.1691075570463.png
OK my issue is resolved. The battery voltage was set to 24V. It kept the setting from the previous time I connected. I configured the bulk and float voltage also manually. All is working great now.
