I’m not sure if my solar is working the status is always off I’ve never seen it change I lost voltage the other day so had to plug in to shore power to bring it up any advice I’m struggling to understand
There is no voltage from your solar panels. So you have to check everything from the charge controller on the PV side all the way to the panels.
They have either a break in the wire, melted/poor connection, your DC disconnect or fuse tripped. Or something as simple as the connection in the mppt itself.
If a fuse or DC breaker blew, check why.
38 People are following this question.
