bobscullion avatar image
bobscullion asked
IP65 12/10 negative,
I've purchased the IP65 12/10 to wire permanent into my VW camper to charge my 130ah AGM battery when on shore power/hook up, do I connect the negative cable to the vehicle earth or can I safely connect to my smart shunt/battery monitor so I can see at a glance on my monitor rather than have to get my phone and check the app?
Thanks
ip65
Paul B avatar image
Paul B answered ·
conecting it to the earth point or engine block should be were it goes if the smart shunt is installed correctly
