Only 2 mppt chargers, an inverter and a smart shunt are connected to CerboGx, where do I connect the third mppt charger. Also, the graph on the dashboard does not show the electricity consumption.
How have you connected the mppts you have already? Ve direct or can? Are they capable of can connection?
What i verter do you have? If it is a victron is it connected to the ve bus port? Just double check it is in the correct one, it is a common error to out it in the wrong one.
All devices I use in the system are Victron brand, only 12 V 400 Amp Lifepo4 battery is made in China.Also inverter connected to the main 12 V busbar.I connected 3 PCS smart solar Charger as parallel to the main 12 V busbar .I tried connecting the Ve-direct output of the 75/15 mppt smart solar charger to the USB input of the cerbo gx with a cable, but the cerbo gx did not see the 75/15. I turned Cerbo on/Off for resetting. But nothing changed in Dashboard.
Dear Alexandra ı am waiting your answer , thank you very much indeed.
Yours Faithfully,
Yours Faithfully,
I Have;
two 100/30 MPPT Smart Solars, one 75/15 Smart Solar, one Smart Shunt, and one Phonex 12/1200 inverter in the system. One 100/30 MPPT and another 100/30 MPPT are connected to the three VE-Direct inputs of the Cerbo GX. The Phonex 12/1200 and one Smart Shunt are also connected. One Smart Solar 100/30 MPPT is connected to the USB input of the Cerbo GX. I was unable to connect the Smart Solar 75/15 MPPT charger to the Cerbo GX. You can check the name of the system from the ALPAGOT server.
Although I can see the AC consumption figures on the Dashboard, the AC consumption value does not show on the graph. Why is this? Do you have any suggestions? I would appreciate it.
Here are some possible reasons why the AC consumption value is not showing on the graph:
64 People are following this question.
