Hello.
I have a Victron Quattro, CCGX panel, VE Bus to NMEA cable and a VE CAN to NMEA cable.
These 4 items are all connected as per Diagram 1.1 here:
https://www.victronenergy.com/live/ve.can:nmea-2000:start
Data from the Quattro reports fine on the CCGX (NMEA bus OK) - However I am unable to change the Quattro’s mode (On/Off/Charger Only).
The CCGX screen shows the mode change, but nothing actually changes on the Quattro.
Further down on the page link above I did notice that the VE CAN is stated as being “read only”
CCGX does not send any information to the N2K network.
Does this mean the CCGX it will not send out the required data to request the Quattro change mode?
I must add that what I am ultimately trying to achieve with this equipment......
1) I want to have the ability to control the Quattro ON/OFF from the CCGX panel.
-I do not need (or want to) to send any commands from our systems NMEA network to control the Quattro.
2) I would like our vessels NMEA network to be able to monitor the running state of the Quattro.
Best Regards
KR
