If you see below on the screen shot from the Display Console, it shows as PV max 2019w. The panels I have in my place is 6 x 305w panels which totals to 1830w.
Can somebody let me know if this is an issue? Please advise
It is quite common to see more than the rated PV power if the conditions a right. It's called cloud edge effect. In light cloud or when a while cloud goes past the sun it can actually magnify the light and cause more light to fall into the area than normal sun in clear conditions.
I have a 2.6 KW array and I have seen 3,2KW from it under these circumstances.
PV modules are rated under Standard Test Conditions (STC) which is 1KW of light power per 1 square metre at 25 degrees celsius which is equivalent to sunshine on a clear day.
9 People are following this question.
