galenrto avatar image
galenrto asked
DVCC - Charge current limit when no grid detected (grid feed-in enabled)
The Cerbo GX manual states the following:
"When DC-coupled PV feed-in excess is enabled with ESS, the DVCC system will not apply the DVCC charge current limit from PV to battery. This behaviour is necessary to allow the export. Charge voltage limits will still apply."
My question is: With these settings in place (DC-coupled PV feed-in excess enabled with ESS), if the grid goes down, making export impossible, will the DVCC system now apply the DVCC charge current limit from PV to battery?
Thanks in advance.
ESSDVCCcharge current limitcurrent limit
