shawncraig31 avatar image
shawncraig31 asked
Compatible mppt
Hello, I have the mppt 150/70 was going to use this for an array on the roof of rv. Have a couple of 88 w panels that I was going to use as a suitcase array. I don’t need a big controller for the second but the small mppt’s don’t have a can port to daisy chain to the 150/70. What options do I have to make the suitcase communicate with the normal controller. Thank you
MPPT ControllersVE.Smart Network
Alexandra avatar image
Alexandra answered ·
@Shawncraig31
There is always the option of a smart network. It would require a battery sense or a shunt.
Do you need to limit charge current for any reason? If not then in all honesty synchronization is not a complety necessary thing.
shawncraig31 answered ·
I have the smart shunt. Just wanting to be able for everything to commute properly. If I run a be direct cable to cerbo does this then I’m good to go. I just don’t know if it will
kevgermany avatar image
kevgermany answered ·
VE.direct to Cerbo for bothe MPPTs will work.
MPPT Product Page
MPPT Error codes
VE.Smart Networking Manual
