I want to ask if Victron has a library of released updates for their devices? (also with older editions, not just the latest)
If so, where can it be found?
Thanks.
Thanks.
Victron professional. You can make your own account there as a user.
@Alexandra @Matthias Lange - DE Hi, I looked there, but I didn't find what I was looking for.
Specifically, I am looking for older firmware for mppt blueSolar 150/45 there are only version 1.61 :(
That's a good question :)
I have firmware 1.61 now on mppt 150 / 45, before that I suspect 1.59 (appreciate older ones too) but not sure if it was really a revision of 1.59. I want to try to downgrade it because X times a day after switching to ESS I get error messages, #67 BMS not connected, dead VeBus battery... 11monts 0 errors of this kind :) ... (not fixable according to repair guide)
If possible I would take it down one level and see how it works and if it does the same (errors)... but I didn't find it.
From what I noticed in the discussions, many people have this problem after upgrading to 1.61…
I am 99.99% convinced that it is a SW error and firmware incompatibility between components :)
Because he didn't get these errors before updating and switching to ESS.
Maybe it's not a bug, maybe is a future from ESS, it's just not well documented :D :D :D who knows...
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
44 People are following this question.
