andrii avatar image
andrii asked
Connect EV charging station
Hello everyone! I have a tech-phase input and a single-phase Victron Quattro 5kVA system. If I connect one phase of the EV charging station to the quattro output, and the other 2 phases to the mains, will the EV charging station work correctly? The power of grig is 22 kW/
Thank you!
ev charging station
matt1309 avatar image matt1309 commented ·
EVCS can run on a single phase or three phase. And assuming you have grid connected to quattro the grid connection will be able to pass through if the EVCS is set to charge at a rate higher than quattro can provide from battery/solar.
