pkkrusty avatar image
pkkrusty asked
Quattro Temperature sensor available from MQTT?
When our 15kva Quattros are on the edge of overheating, the red temp LED flashes. I assume there is at least one temperature sensor inside the unit. How can I access that temperature data? Is it passed to my CerboGX such that I can get it from MQTT? Or do I need to set up a Modbus bridge connected directly to the Quattro? Or some other method?
MultiPlus Quattro Inverter ChargerTemperature Sensor
pkkrusty answered ·
Bump. Anyone?
