harrison88 avatar image
harrison88 asked
Temperature sensor: VE.Bus vs SmartShunt
My agent sent me a wiring diagram with the temperature wiring from the SmartShunt onto the battery. However, I note in the manual for the VE.Bus it suggests the temperature wiring could go from there.
Is there a benefit of having it from the SmartShunt or is there a better way of doing it?
I also have a MultiPlus 12/500/20 and BatteryProtect.
Thanks!
Temperature Sensor
Alexandra avatar image
Alexandra answered ·
@Harrison88
The real question is why do you need it?
What battery do you have? Does it need temperature compensation for charging (lead acid agm)? Low cut off (lithium)
And do you have a GX? If not then use it in the multiplus.
harrison88 avatar image harrison88 commented ·
Hi, I have two AGM batteries. No GX.
By use it in the Multiplus, do you mean connect the temperature wire to the Multiplus instead of the VE.Bus or SmartShunt?
Victron temperature sensor disambiguation table - which product supports which sensor
