P.H.J. Sibbing avatar image
P.H.J. Sibbing asked
Losing BMS after low SOC
VRM.jpgBattery.jpgI lost my BMS now twice.
1) i could recover the connection to the BMS , after SOC dropped below 50% ( SOC treshold was 50 % in VE.Bus of the Multiplus). Disconnected the Battery from the
2) Nextday , I lost Connection again , at 70% SOC, (but could not confirm this figure) Have not been able to recover connection.
BMS: Seplos 10E , Can:Victron, model 1101-SP75 , Software Ver 16.4
BMS worked fine untill lost connection. Checked BMS with Seplos tool. Nothing particular. Is working correctly
Have Re-installed Venus OS ver 3.0, Large, no Luck, no BMS detected.
In system Setup, only Lynx Shunt and Multiplus Visible.
Did anything change in the CAN protocol in Venus OS ?
Is there a setting in Venus OS i can alter or remove, so the Cerbo will re-search for the connected devices. ?
Can bus no errors! Cable replaced no difference.
Removed the Shunt cable , Nothing changed , reconnected, all data of battery popped-up as before .
BMSVE.Can
@P.H.J. Sibbing have a look through Andy's videos you might get some extra info.
You using the correct comms cable?
P.H.J. Sibbing answered ·
It worked fine for 2 month's and suddenly in the middle of the night it stopped after a Low SOC alarm.
So what about the cable ? I can try another spare cable to double check
The message was due to me unplugging the CAN Cable from the BMS
Thanks for the support
Just updated Venus OS to version 3.10~15 ( from ~1 to ~12) and suddenly at ~15 the BMS re-appeared.
So Cable is fine, was an software glitch somewhere which lasted 2 weeks
Victron VE.Bus BMS product page
Victron 3rd party BMS compatibility page
