Has anyone managed to get a 2.4/2.8 display up and running on pi zero 2w if so can you pass any info i have managed to get the screen to change from bright to dark when booting up but no display have tried headless on and off but no menu display.
Do we assume you are running venus os on this Pi? What version are you trying?
Not sure it supports GPIO displays it was designed for HDMI.
I have version three and it is running ok in the past i have run venus os on a raspri 3 and 4 and had the display work running hdmi and gpio the only issue i had then was screen blanking , im not so concerned with screen blanking just would like to get the display to work,i have run some other software and managed to get the screen to work,so i had the correct driver.Any further suggestion Thanks
After looking at another article have fixed the issue.i changed the cmdline file which got the display running.
replacement dwc_otg.lpm_enable=0 echo fbcon=map:10 >> console=tty1 consoleblank=300
original dwc_otg.lpm_enable=0 console=serial0,115200
https://github.com/wild-mustango/VenusOsTFT35
and a big thanks to Wildmustango for his input if all else fails read read again :)
34 People are following this question.
