Mark Anderson avatar image
Mark Anderson asked
Grounding/bonding mixed dc systems to rv
Hi all
Just installing 48v system in my rv (solar + shore power inputs)
Infused about grounding.
If I connect my battery negative to chassis, isn’t anything else I connect to chassis effectively connected to battery negative?
Biggest concern is vehicle is electronics. What happens if I have a fault and 48v goes for the chassis? That’s also going to my starter battery and vehicle electronics.
Anyone got a good guide on correct way to ground/bond?
Grounding48v battery
kevgermany avatar image
kevgermany answered ·
I understand your concern. But it's a non issue.
The AC will also have a chassis ground. On neutral. Much higher than your batteries.
The positive side should be correctly fused. If you wish add a DC breaker to that side.
Ground, earth and electrical safety
