bladerunnervf avatar image
bladerunnervf asked
controlling grid export : Quattro 48V/8000 or 48V/5000 or 48V/10000
Hello I have done several searches on the forum and looked through a good many topics by cannot find a simple answer to this question
I have also searched through the Quattro manual
so apologies if I missed it ..
Q) Is it possible to set the export level to the grid for the Quattro 48V/8000 ?
By default my DNO will accept 5kW to be exported to the grid, a little more than the usual 16A 230V 3.68kW. So I wondered if it's possible to set a specific level.
Thanks
MultiPlus Quattro Inverter ChargerESS
mvas avatar image
mvas answered ·
May be possible using ...
the Maximum Feed-In (watts) field
On the "Grid Feed-In" config screen
Alexandra avatar image
Alexandra answered ·
@bladerunnervf
Yes you can in the ESS menu.
A caveat though, not all AC PV can be controlled so stick with DC PV on your install.
