rvreallydoingthis2 avatar image
rvreallydoingthis2 asked
Voltage drop - battery life
Fighting the South Florida heat!. I find myself solely relying on my solar system for weeks at a time. My system is a 24v system (components listed below) the battery bank was with 8 - 100 amp Battleborn batteries. My batteries would go from 100% charged at say 10pm and by 6am they would be down to 18-20% and the volts would drop low enough to shut they system down with a low battery alarm. (Just as the sun would start coming up) (yes, I am attempting to run 2 ac units to keep the 45 ft RV somewhat cool)
I figured adding a few more batteries would get me the extra time needed for the solar panels to start charging the batteries again. I added 2 more batteries, wired them in 2 seperate 12v strings of 5 batteries wired in parallel and then connected to the other string of 5 in Series to get the 24 volts needed. I was thinking that would be 1000 amp hrs.? (Which is what I changed the battery settings in my smartshunt too)
*Correct image updated
Now it seems I have plenty of battery life in the morning about 50% but my volts are now dropping off by morning enough for the multi-plus's to shut off with a low battery alarm.
I am hoping that I'm just not understanding something (or a lot) and I have a setting, or two, or three wrong.
Any educated assistance would be greatly appreciated I would also love to find someone on the southeast coast of Florida who could look at the system.
System:
2 - Victron Multiplus 24v/3000/70amp -- Split phase 180.
2 - Mppt 150/100/TR ve can.
10 - battle born 100 amp batteries. 2 seperate 12 volt strings of 5 batteries wired in parallel and then connected in series to make 24 volts.
8 - 330w solar panels (2640 W) wired series/parallel and broken down 2 arrays of 4 panels
Smartshunt 500A/50mV.
Cerbo GX with touch 50
Orion 24/12-70
Generator - Onan 5500
Auto transformer 120/240/100 amp
system designbattery capacityvoltage drop
rvreallydoingthis2 avatar image rvreallydoingthis2 commented ·
10-batteries.pngOops, I actually attached the wrong image for the battery configuration. *correct image
mvas avatar image
mvas answered ·
1) Note: Your schematic diagram actually shows 10 batteries connected in series! Not the "2S5P" configuration that you stated. But I do understand that you have 2 battery banks wired in series, with each bank having 5 batteries wired in parallel = 24 Volts. Correct?
2) Can your Solar Panels actually produce enough Watts-Hours = ( watts x number of hours sun ) to run your daytime loads AND to fully recharge this larger battery bank?
3) You changed from a 24 volt x 400ah battery bank, to a 24 volt x 500ah battery bank. No, you do not have a 12 volt x 1,000ah battery bank
4) Is you new larger battery pack at 100% SOC at sunset? What is the final / highest charge voltage at sunset?
Thank you for your response. I actually attached the wrong photo showing the battery wiring. I uploaded the correct one. To answer your questions. Yes, on most days I have no problem reaching 100% soc during the day before sunset. I reduce my load needs by only running 1 ac to keep the RV at about 82 degrees. If it's cloudy and I am not at 100% by sunset I run the generator for a bit to get me to 100%.
I would like to have solar take on more of the load and use the battery bank less but was leaving that question for another post. Lol
mvas avatar image mvas rvreallydoingthis2 commented ·
1) What is the actual final / highest voltage at sunset, when your system "thinks" battery is at 100% SOC ?
2) What is your cut-off voltage? And what is the % SOC per the system.
3) Did you change your settings to 24v 500ah? ie not 1000ah
klim8skeptic avatar image
klim8skeptic answered ·
@Rvreallydoingthis2 your 10 batteries gives 500Ah @ 24v.
4 comments
Yes this ....
This is a common miscalculation.
You have 1000AH at 12v but 500Ah at 24v
12V x 1000ah is 12, 000wh or (12kWh)
24v x 500ah is 12, 000wh (12kWh)
So still the same energy stored, just at different system voltages.
The battery diagram is definitely incorrect.
rvreallydoingthis2 avatar image rvreallydoingthis2 Alexandra ♦ commented ·
Thank you for your response. I realized I posted the wrong photo of my battery bank wiring. I uploaded the correct one.
kevgermany avatar image kevgermany ♦♦ rvreallydoingthis2 commented ·
Maybe I'm missing something, but looks like 12V to me in the corrected diagram.
mvas avatar image mvas kevgermany ♦♦ commented ·
Diagram looks like a 2S5P battery bank = 24 volts
kevgermany answered ·
What is the power consumption of each AC, fridge etc.
Need to calculate total energy consumption overnight, then make sure the battery capacity is double that or higher.
