martin-fi avatar image
martin-fi asked
EV Chariging Station - Charging from Grid instead of ESS battery
Hello Community,
we got a customer who has 3 EVs and charges all of these with a Victron wallbox.
In most cases he wants to charge the EVs from the grid. But in Manual mode the Charger uses first the ESS battery.
Is there a solution (I don´t mean the "keep batteries charged" mode in ESS) to charge directly from grid ?
ev charging station
nuxland avatar image
nuxland answered ·
I want to do the same thing in winter and only thing I can think about is to use Node-Red.
I would create myself some interface there that I can set GridSetPoint to 11kw and then same time set EV Charger to manually charging with the same 11kw.
There need's to be some watchdog also in node-red to detect when charging stopped/finished to set GridSetPoint back to 30W :)
ponzoa avatar image
ponzoa answered ·
In the latest firmaware of the EVCS, you having a setting which defines upto which point you can use battery for EVCS.
martin-fi avatar image martin-fi commented ·
Thank you. This helps but a third mode ("Use just PV Power and Grid") would be nice.
