Kevin avatar image
Kevin asked
What's wrong with my multiplus inverter-charger?
Hello all. I have an issue with the charge side this Multiplus Compact 2000. It is only controlled by the ve bus bms, mains detect. The charge relay engages briefly when shore power is turned on. The middle light goes yellow briefly and then the relay disengages. It will sometimes hold up to 2 seconds. When the switch is down in "charge only" position it eventually went to fault on the Cerbo GX panel.
The red alarm light does not come on except when I turn off the DC battery switch while attempting a full reset. AC & DC voltage is good and all connections are tight. All other sources of charge work well and it inverts well.
Faulty relay?
Anyone have similar issues?
All ideas are greatly appreciated!
multiplus ve.bus
