I charged my drop-in Lifepo4 battery 100A 24V (25.6V) with built-in BMS without bluetooth with 28.4 V to 100% full. After the charger is switched off, the Victron smart-shunt app gives a resting voltage of 26.6 volts. Is that normal?
It depends on if you set that for float or not.
And what you mean by fully charged. How many amps was it drawing at the 28.4v did it hit absorption.
38 People are following this question.
