Thomas Manthey avatar image
Thomas Manthey asked
How can I configure 2 Smart Shunts for use as a battery monitor?
In my 48V ESS system, I use 2 groups of 2 24V batteries connected in series, in parallel. I have provided a Smart Shunt in each group to monitor the SOC and the midpoint deviation. The batteries have their own battery management system integrated and communicate via minor voltage and current differences.
Unfortunately, I can only specify one device in the battery monitor. As a result, the battery's charging capacity is only half of what it should be.
How can I configure a virtual battery monitor that displays the sum of both currents and the mean value of the SOC and voltages as Battrie SOC and voltage?
ESSLithium BatterySmartShunt
matt1309 avatar image
matt1309 answered ·
Hi @Thomas Manthey ,
I'm not aware of anything out of the box other than getting another smart shunt to monitor the whole pack (easiest in my opinion unless you're good at python/know venus os).
If you did want to go the virtual battery monitor route I imagine it's possible using a custom drive to make a Virtual battery monitor and then populate the values of that virtual device by reading the dbus addresses of the existing two battery monitors and storing them into the virtual battery dbus.
velib_python/dbusdummyservice.py at master · victronenergy/velib_python · GitHub
And edit the service name to com.victronenergy.battery.tty01
Then look at the various dbus addresses noted here:
dbus · victronenergy/venus Wiki · GitHub
This might be a good starting point if you want to go down that route.
I have experience creating a virtual device. The dbuysdummy.py does the bulk/all of the heavy lifting in setting up the virtual device. However I've only ever used it for virtual tank sensors so to populated the data via dbus, I've instead done that via MQTT. Whereas I imagine you'd just read and write directly from the dbus rather than going via mqtt. I've not had experience is reading/writing to dbus I think there are functions setup in the github links above but I'm not clued up on them enough to give any further detail.
You may also be able to populate said virtual battery monitor using node red if that's easier than reading/writing dbus via python.
Personally I don't like the idea of adding another system (Node red) as just feels like another potential point of failure, especially when it's more important data like battery information. So if you're going the virtual battery monitor route i'd personally stick with python. (Probably also doable in C++ if you prefer but a lot of the github info I've seen is python)
You may also get some more success moving this to modifications section if you're writing a custom python driver for venus os. (Let me know if you go this route, Id be interested to see how the custom driver comes along).
EDIT: I've assumed in the above that there's no safety implications of using the average of the two battery monitors to populate the virtual monitor. This may be an unsafe assumption on my part. Make sure you're confident that it's safe to use average. ie BMS have applicable protections for example in the event that one pack voltage spikes high and the other spikes low => nice average voltage but in reality both packs are unsafe.
4 comments
Thomas Manthey avatar image Thomas Manthey commented ·
Hi @matt1309, thank you for your quick reply. Normally I program in C, C++, Assembler and Pascal. Why not Python as well? ;-)
If you have experience with programming device drivers under Linux, I would be very interested in this knowledge. I'll have a look at the sources in your answer first.
But now I have to mount the solar panels on the roof again while the weather is still good.
matt1309 avatar image matt1309 Thomas Manthey commented ·
No worries,
I've not got much experience with custom drivers on venus os, although for basic devices the dummydbus python script really has done most if not all of the setup for you.
I personally only use it and a raspi zero to get heating oil tank data into venus os.
(I have an old apollo ultrasonic tank sensor 433hz, I capture the data from 433hz signal with pi zero using rtl_433 program, format it a little in python and do some maths to work out volume of oil remaining from the depth data from the sensor before sending to venus os via MQTT. With the above dummydbus.py running on venus os to spoof a tank).
If you're familiar with using dbus and relevant apis/libraries then making the battery monitor driver might be a doddle.
(Personally I'm not very familiar with dbus and Java is my only partially competent language, python and C++ if i'm feeling brave. So making the battery monitor described above would be too much of a mammoth task for me).
I imagine for someone experienced the github documentation would be more than enough to have a running start at customising your setup.
Although others are right I think there's probably easier/more appropriate and safer solution to your problem...
Hi, @matt1309 I have already done a lot of hardware-related programming for the Raspberry, but unfortunately not yet under VenusOS.
So I guess I have no choice but to learn Python.
Only thing I'd flag is venus os is embedded Linux so can be a bit more time consuming adding useful programs either by opkg or compiling from scratch.
Alexandra avatar image
Alexandra answered ·
@Thomas Manthey
A smart shunt by design is meant to measure one bank, that is the entire capcity and amps going to and from it. Also the monitoring system is set up for one master shunt.
The shunt already measures midpoint as a feature, so you don't actually need two shunts for that.
Hi, @Alexandra,I hope it doesn't sound rude if I ask you to read my original description again carefully. I have connected 2x2 24V batteries to 2x48 V in parallel. So I also have 2 different midpoints and 2 currents to monitor.
Alexandra avatar image Alexandra ♦ Thomas Manthey commented ·
Not at all @Thomas Manthey
I know the picture below is for 24v and a battery balancer (which monitors and corrects midpoint deviations), but will work for 48v with a shunt as well for midpoint monitoring.
Thomas Manthey avatar image Thomas Manthey Alexandra ♦ commented ·
If you are using the batteries in that way, you are right. But at the datasheet of the batteries I'm using is that kind of interconnection not described. It is only allowed to connect 2 in series >OR< 2 in parallel. Maybe the communication that takes place between the single batteries, will not work correctly, otherwise. So I must measure 2 midpoints and 2 currents separately, what in view of redundancy is not to bad. Because I have a dc NH-Fuse in series of each group, I'm able to switch it off and replace a group on failures.
derrick thomas avatar image
derrick thomas answered ·
There have been a few fellers on here that have created a virtual battery driver that can enable you to select the virtual driver as the main battery for the Venus device, and select which devices you want to report to the virtual driver to feed the aggregated information. Do a forum search for virtual battery driver or battery aggregator.
I did the search as you described. Unfortunately, I could not find a post that addressed my problem. Could you please add a link to the post you are talking about?
derrick thomas avatar image derrick thomas Thomas Manthey commented ·
Here is the GitHub for the virtual driver
https://github.com/arrow1800/Victron-VirtualBattery
Thomas Manthey avatar image Thomas Manthey derrick thomas commented ·
Thank you very much derrick! I will study this solution an will try to understand the python script.
solarsnow avatar image
solarsnow answered ·
https://github.com/Dr-Gigavolt/dbus-aggregate-batteries i use this to aggegate 3 battery banks with individual BMS.
