hhubred avatar image
hhubred asked
Multiplus 3000 12v - Assistant Setup
Hello Everyone, Im trying to figure out how to make my Multiplus 3000 respect my BMS charging profile across the Can-Bus. I believe it's through maybe an "assistant".... Can anyone tell me if I'm at least on the right track?
I'm using a Orion Jr2 as my BMS feeding a Cerbo GX via the Can-Bus
Heath
Alexandra avatar image
Alexandra answered ·
@hhubred
Other than programming the units for the correct voltages, DVCC does the rest.
If the battery (which is not on the official compatible list) send the right signals to the system through the GX, the system will follow. DVCC is the way that happens you can interact there with the features.
The assistant that I think you are referring to requires the bms to be wired to the inverter itself, not over can bus. More information here.
hhubred answered ·
Alexandra
, thanks for the reply.
With that being said. The whole reason I started down this path was because I didn't feel as if DVCC was working between the 2 because the charger appeared to be charging past what was set in the BMS..
When you say "Other than programming the units for the correct voltages, DVCC does the rest."
Do you mean the unit as in the Multiplus or as in the BMS? or both? I'm under the presumption its the BMS.
Heath
@hhubred
The multiplus and any other chargers in the system including MPPTs. They all need to be programmed.
