dd33 avatar image
dd33 asked
Can the PHOENIX SMART IP43 charger also be operated with "DC" instead of "AC"?
can the PHOENIX SMART IP43 charger also be operated with DC – „direct current“ (instead of AC – „alternating current“)?
I have read the user manual for PHOENIX SMART IP43 here:
https://www.victronenergy.com/upload/documents/Phoenix_Smart_IP43_Charger_120-240V/Phoenix_Smart_IP43_Charger_120-240V-en.pdf
I also read "the following" in the user manual:
Nominal input voltage - AC supply 120 – 240VAC
Input voltage range – AC supply 85 – 250VAC (full power from 100VAC, startup from 90VAC)
Input frequency - AC supply 45 - 65Hz
Input voltage - DC supply 90 - 375 VDC
"Shore power" is not "available" at all times - as owners of ships or caravans in particular know. Therefore, it is advantageous – if customers have solar panels. Now I would like to ask - "what" customers have to pay attention to - if they want to "supply" the PHOENIX SMART IP43 - with DC („direct current“) from solar panels - so that a 12-volt battery is charged "correctly" - with the help of the PHOENIX SMART IP43 charger? So which "accessories" does Victron recommend - if customers want to "pass on" DC („direct current“) from solar panels to the PHOENIX SMART IP43 charger?
Here is an example: Victron also offers solar panels. Here is a link:
https://www.victronenergy.com/upload/documents/Datasheet-BlueSolar-Monocrystalline-Panels-EN.pdf
Article number: SPM040201200 20W-12V Mono 440x350x25mm series 4a
NET WEIGHT: 1.9
NOMINAL POWER (WATTS): 20
MAXIMUM POWER VOLTAGE (Volts): 18.5
MAXIMUM POWER CURRENT (Amps): 1.09
OPEN CIRCUIT VOLTAGE (volts): 22.6
SHORT CIRCUIT CURRENT (Amps): 1.19
I would now (Just as an example/ Of course only - if the system voltage of solar panels would "allow" it.) connect 5 solar panels in "series". The MAXIMAL POWER VOLTAGE would then be: 92.5 volts. MAXIMUM POWER CURRENT would be: 1.09 Amps. NOMINAL POWER would be: 100 WATTS. And now it would be interesting to know - which "accessories" are recommended by VICTRON - so that I could forward the DIRECT CURRENT to a PHOENIX SMART IP43 charger? So e.g. the "cheapest" method - or other (more expensiv – but sure „hight quality“) options?
Thanks very much.
dd33
Phoenix Smart Charger ip43
kevgermany avatar image
kevgermany answered ·
Solar panels require a solar charge controller between the panels and batteries. Best option is usually the MPPT type. I doubt that you're going to get adequate performance, if any, powering a Phoenix with them. Plus there is the issue of potentially feeding AC into the panel outputs.
dd33 avatar image
dd33 answered ·
Thanks for the information. I've "now" looked for "MPPT SOLAR CHARGERS" - and I have to agree with you - that it would be (probably) the best (or „lightest“) solution - to use MPPT solar charger.
Before - I was only thinking - whether it would be ("purely theoretically") possible - to charge a 12 volt battery with "PHOENIX SMART IP43 CHARGER" - if you don't have "shore power" available (E.g.- if you use „ship" or „caravan“). In user manual (from PHOENIX SMART IP 43) I read - that the charger also accepts DIRECT CURRENT "from 90 volts". So I thought about - "how exactly" (I.e. with "help" - from which other "devices" / Or: Which connectors would be needed?) the direct current from the solar panels – can be forwarded "to" the PHOENIX SMART IP43.
Because I didn't see any connections for "direct current" on the outside box of "PHOENIX SMART IP 43 CHARGER" – it interested me. I can only assume - that for example - a "special" laboratory power supply is required for this „problem“. Or maybe a "special" power supply from Victron - which "somehow" forwards the direct current "to" the PHOENIX SMART IP 43 CHARGER. Or: The "direct current" is (maybe) converted in the (special) power supply - to alternating current.
Not much to add to what @kevgermany said.
Simple answer: Yes
The prerequisite for this, however, is a proper constant power supply or DC generator that can supply a suitable DC voltage and current. Solar panels do not work properly for this.
dd33 avatar image dd33 Stefanie (Victron Energy Staff) ♦♦ commented ·
Hi Stefanie, that's exactly "what" I wanted to know. Thank you for the info. With best regards. Daniel
