I have a Victron 100/30 smart mppt charger on a 400 watt system feeding a 200ah LifePo4 battery. The last few charge cycles the float voltage (set at 13.5 volts) is truncated and drops below float after 2 hours. Full sunshine and good current should maintain float during sunsine hours. Correct? No clouds in the sky during this phenomena. Any good thoughts on why this occurs?
