pierrick-ausseresse avatar image
pierrick-ausseresse asked
bug report victron connect on windows - history (day -2) not displayed without restart
Hi *
A not that critical issue, for it doesn't impede functionnality. Call it cosmetic.
if you keep tracking history for a Multiplus RS 6000 using windows and USB dongle, day -2 of history will eventually display data from day -3 but label still it as day -2
if you restart victron connect (disconnect / reconnect is not enough, program restart is needed) the days in history will display again correctly
with the issue present (before program restart) 2 days ago is actually 4 days ago and 3 days ago is 5 days ago
After restarting victron connect history is showing up correctly. there is 5 minutes between the two screenshots.
this issue requiere to have victron connect operating for more than 2 days in a row.
Victron connect version is 5.90
PS : there is at the moment no GX device in the system, which explain why it charge at full power while thinking it has 100% state of charge (it is around 40% in reality). My system has DC loads that the Multi RS cannot inlcude due to lack of BMS communication.
bug report
Thiemo van Engelen (Victron Energy staff) avatar image
Thiemo van Engelen (Victron Energy staff) answered ·
Hi @Pierrick Ausseresse
Thank you for reporting this issue. We will look into this.
Kind regards,
Thiemo van Engelen
