colinhaus avatar image
colinhaus asked
BlueSolar PWM Light Charge Controller 12/24V Power Up Sequence
The manual states "Always connect the batteries first, in order to allow the Controller to recognize system voltage"
This leads to the question, "What will happen if the solar panel is connected first?" There may be occasions, for example when a fuse to the battery is replaced, that the solar panel is already connected. Will the system fail and if so will it fail safe? What will be its behaviour?
BlueSolar PWM
