Will there be a software update for the Smart Solar RS 48/6000 230V in the future. So that ESS is available?
Are you referring to the Multi RS?
The Inverter RS 48/6000 is specifically for offgrid (i.e. no AC input application - i know as i have one.)
It is not as advanced at the Multi 2 and the Quattros though, as you cannot set a grid code there. But from what i have seen it does have ways to prioritise solar for loads.
Hi Alexandra,
Thank you for your reply. That is indeed the RS I am referring to.
I knew that ESS was not yet supported at the time of purchase. However, my supplier has indicated that there will most likely be an update that this is possible.
It also turns out to be very complicated for my supplier to get an answer from Victron. When and if there will be an update
Thnx, Rob
ESS design and installation manual
53 People are following this question.
