victor-altenergo avatar image
victor-altenergo asked
Why does the battery level decrease to 0% ?
video discharg 1.mp4scrin-3.jpgscrin-2.jpgscrin-1.jpgThere is a decrease in the battery level to 0% under the condition of a normal floating charge during the day when the solar charger is working. In the dark, the charge level% does not change.
ESS system – Multiplus II 8000, charger 450/100, cerbo , GEL battery 200ah 4 pieces
Paying attention
– in the battery window of the VRM system, a discharge with a small power of 50-400 watts is observed.
- There is a difference between the power of the tracker and the power of the charger in the solar charger window of the VRM system. This difference depends on the power, the more power the greater the difference. This cannot be a bad charger efficiency, the difference of 400-600 watts is quite larg
if you turn on the equalization charge, then the charge level may change to 85 or 90%. if you turn off the grid , then the charge level will also change, it can become 80%
Multiplus-IISOCrs450
