emanon2 avatar image
emanon2 asked
BMV-712 battery monitor will not update firmware
When I checked my app today the battery monitor was working. Then it requires me to update my firmware to v4.13 and it fails. I have shut down the power to it and disconnected from my device and reconnected and tried from another device multiple times. The main device has a BT200 error. My app has had a D93, D31, and D33 error when it is trying to uodate. It also says that there is no firmware on the device. The first time it tried before it failed it went from 4.x to this new firmware. img-1644.png
BMV Battery Monitorfirmware updatebt200
kevgermany avatar image
kevgermany answered ·
Try disconnecting the monitor completely for a while, then reconnecting.
If this doesn't work it might be possible to reapply the update if you have a usb/vedirect cable.
otherwise needs to be fixed by the dealer.
