marekp avatar image
marekp asked
Cannot insert images in my post.
I encountered the problem inserting the images to my posts.
Some times system lets me insert no problem but after one or two or three inserts the next one gets rejected. Size of the image or image type does not mater.
This time the image was inserted and you can see what massage I get when there is a problem.
victron community
How do you insert the images?
Do you drag and drop them or do you click on the button and select the image from you computer or do you use a link to an image?
You can also insert an image with Ctrl + V if it is in you clipboard.
marekp avatar image marekp commented ·
@Matthias Lange - DE
I tried dragging from the desktop or selecting quick insert (insert image). When I do the later, I have to select the image from the list.
As you can see this problem does not show up all the time.
Some time I have a problem with the second image and the other time with the third or fourth.
