scat avatar image
scat asked
How long can a Quattro Inverter Charger 48v Input 5000va power a surge
How long can a Quattro Inverter Charger 48v Input 5000va power a surge of anything between 5000Watts and Peak power 10000Watts?
The reason I ask is that the Schneider XP Pro can hold a 8500 Watt for 30 minutes and it is rated at 6800Watts.
Thanks
Scat
peak
I guess you should use at last the 8000VA Quattro for your setup, better the 10kVA Quattro.
I don't know what a "Schneider XP Pro" is but it might also have a short inrush current that is even higher.
https://www.youtube.com/watch?v=4SXtGIx0x5w
