parateam avatar image
parateam asked
ERROR: Max Charge Voltage (52.4V, Pylontech) ignored, when limit Grid feed-in in ESS settings
Hello, there is a bug in the system. My Setup:
3xMP-II 3000, 3xPylontech 5000, 1xMPPT RS 450/100
Victron stops charching above 52,4V with Pylontech batteries. This works perfect until i limit the Grid feed-in in the ESS settings. AC and DC feed-in is activated.
AC inverters (Kostal an Hoymiles) are connected to the AC out1 of the MP-II and are not regulated with the GX-system.
I've got an Overvoltage error from the Pylontechs: 56,7V !!!
Is there a solution for this?
overvoltagefeed-in limit
parateam answered ·
Can anyone help me? Again an overvoltage alarm!
parateam answered ·
A poor solution, but no more alarms. The voltage kepps below 52,4V.
My Workaround with NodeRed:
1. calculate a summary of Input-Power of L1 to L3.
2. if value is below -1500 (W) switch PV-Charger off, otherwise switch on (1min interval)
