As per the title - in my Cerbo GX, when I go into battery detail I see "NaN KAH" in the "remaining" field. What is that?
KAH could mean (unkown) AH ?
What battery do you have.
This may help:
https://www.victronenergy.com/live/battery_compatibility:start
You'll need to check/double check the setup using REC-BMS own setup instructions. You may or may not get these values to show properly.
Try the community search function. There are other REC-BMS threads.
It's a self built 8 cell 2P4S 560Ah/6.75kWh battery using a REC-BMS Active BMS that communicates over CANBUS with the Victron kit.
While the battery is charging there is no remaining time or Ah.
Is the BMS sending that information to the GX device?
57 People are following this question.
