sunsport1996 avatar image
sunsport1996 asked
Victron Blue smart Ip22 12/30 in Motorhome
I recently bought a Blue Smart Charger IP22 12/30 for my motorhome.
I want to use it to continuously charge/maintain the coach Battery 12V 180A semi-Traction
When I drive , the Battery is charged by the Engine's Alternator. When I park and put in the 220V landline , the battery is charged by the Victron .
The Victron is connected directly to the Coach Battery.
When I turn on the lights in the evening, take a shower using the 12V waterpump, the fans of the heating system are running etc.. for example 10Amps in total.
Does the Victron senses this and will keep my battery full ?
Thanks.
victron community
sunsport1996 avatar image sunsport1996 commented ·
Is this configuration the best solution for my motorhome ?
Paul B avatar image
Paul B answered ·
the charger will maintain your battery at its set voltage ie 14volts, and as you turn loads on and off it will adjust as needed.
sunsport1996 answered ·
Thanks ,
I installed it now for a couple of days and it seems to work fine.
It stays on float and when I turn on a heavy user it starts loading the battery.
Just what I needed !
Greetings,
