This is more of a hardware modification. I made a 3D printed push rivet to secure the bottom cover of the Multiplus IIs because often times we install these in tight places where getting a screw driver in would be very difficult. True you could put a Phillips bit in a socket but that's also troublesome when you need to get into it and might not have those with you.
Thoughts?
https://sotasolar.com/blog/victron-multiplus-ii-3000-push-rivet-for-bottom-case-3d-print-stl-file
